查看: 1558|回复: 1
[供应] 8CH Mini CWDM Module
发表于 2014-6-23 14:35:51 | 显示全部楼层 |阅读模式
        4CH Mini CWDM Module
Features:
        High Reliability
        Low Insertion Loss and Better Uniformity
        Ultra High Thermal Stability
        Epoxy-Free in Optical Path
        RoHS Compliant
Applications:
        CWDM System
        CATV Syste
Specification:
Parameters         Unit        CWDM OADM Module
Wavelength Range         nm        1260 ~ 1620
Channel Center Wavelength         nm        1470, 1490, 1510, 1530,1550,1570, 1590,1610
Channel Spacing         nm        20
Channel Passband         nm        λc ± 6.5
Channel No.         λ        8
Insertion Loss         dB        ≤1.5
Adjacent Channel Isolation         dB        ≥ 30
Non-adjacent Channel Isolation         dB        ≥ 40
PDL         dB        ≤ 0.2
Polarization mode dispersion         ps        ≤ 0.2
Directivity         dB        ≥ 50
Return loss         dB        ≥ 45
Optical Power         mW        ≤ 500
Operating Temperature         ℃        -10 ~ +70
Storage Temperature         ℃        -40 ~ +85
Dimension         mm        53.8*28.0*8.0
1. All specifications include the effect of operating temperature and all states of polarization.
2. Values referenced without connectors and insertion loss for a connector-pair is 0.20dB (typ.) and 0.30dB (max.).
发表于 2014-7-19 20:38:29 | 显示全部楼层
现今,印制电路板已成为绝大多数电子产品不可缺少的主要组件。单、双面印制板在制造中是在基板材料-覆铜箔层压板(Copper-(2lad I。aminates,CCI。)上,有选择地进行孔加工、化学镀铜、电镀铜、蚀刻等加工,得到所需电路图形。另一类多层印制板的制造,也是以内芯薄型覆铜箔板为底基,将导电图形层与半固化片(Pregpr’eg)交替地经一次性层压黏合在一起,形成3层以上导电图形层间互连。因此可以看出,作为印制板制造中的基板材料,无论是覆铜箔板还是半固化片在印制板中都起着十分重要的作用。它具有导电、绝缘和支撑三个方面的功能加工性、制造成本、制造水平等,在很大程度上取决于基板材料 。
顺易捷PCB快板打样所有工程费直降50%(低至50元) ,双面PCB批量低至398元/㎡,批量开通免费抽测(直通率95%之上)PCB价格创全球最低,交期最快,品质更好,热线0755-84086168 QQ800055586
