查看: 1324|回复: 1
[供应] 1x3 拉曼WDM模块
发表于 2014-7-15 11:52:30 | 显示全部楼层 |阅读模式
1x3 拉曼模块
Features
        Low insertion loss
        High channel isolation
        Low polarization dependent loss
        Exceptional reliability and stability
Applications
        Access networks
        Metro WDM systems
        Enterprise networks
Item        Unit        Parameters        Note
Wavelength range        nm        1260~1620
Channel centers         nm        1450        1550        1660
Channels         ch        3
Passband        nm        ≥+/-7        ≥+/-7        ≥+/-20
Channel insertion loss        dB        ≤1.2
Isolation (adjacent channel)        dB        ≥40
Polarization dependent loss        dB        ≤0.2
Polarization mode dispersion        ps        ≤0.2
Directivity         dB        ≥50
Return loss        dB        ≥35
Optical power handling        mW        ≤500
Operating temperature range        0C        -20 to 70 0C
Storage temperature range        0C        -40 to +85 0C
Fiber type                MM62.5/125with 0.9mm tube
Connector Type
Package dimensions (L x W x H)        mm        100 x 80 x 10        ABS
Specifications
*.        All the specifications are based on the devices without connector, and guaranteed over wavelength, polarization and temperature.
**.        Specifications are subject to change without notice.
吴海燕  132 6585 3433
珠海飞宇光电科科技有限公司(深圳业务中心)
地址:深圳市宝安区龙华鹊山路口太阳能硅谷大厦A座14楼
电话:0755-28113498-6037
传真:0755-29048624
发表于 2014-7-19 02:36:55 | 显示全部楼层
1,单双面板 5*5CM以内的,pcb打样50元/款;
2. 单双面板10*10CM以内的,pcb打样100元/款;
3. 多层板 10*10CM以内的,pcb打样500元/款。
以上报价工艺为:FR-4,绿油白字,有铅喷锡工艺,数量为10片内,材料均采用建滔KB顶级板材,样板免费全测!
4.单面纸板(94V0)样板,半玻纤,铝基板 小批量生产
特大喜讯:顺易捷PCB快板打样所有工程费直降50%(低至50元) ,双面PCB批量低至398元/㎡,批量开通免费抽测(直通率95%之上)PCB价格创全球最低,交期最快,品质更好,热线0755-84086168 QQ800055586
